I've used my CMT baby lockmiter on a number of projects. It will make a lock miter from 1/2 to 3/4 inch thick material.
There are several things I've learned about this bit set. Setup is critical and the hardest piece to cut is always the one machined vertically against the fence.
1. For the setup. the height of the bit and fence depth is crucial. To get it right, see John Lucas's tips under the A/B method for the lockmiter set at
www.woodshopdemos.com. This is a simple and reliable method to produce a tight joint.
2. The router speed needs to be set just a bit higher than what is normally recommended for the diameter of the bit. I've experience cleaner cuts upping the speed just a bit higher.
3. For taller pieces (in width) than your router table fence is in height, a tall fence is really, really nice for holding the piece square.
4. A feather board holding the operation square when upright against the fence is critical.
I get good results with this method for plywood and softer woods, but I'm still working on my technique with hardwoods.
