I'm not sure if any router has that much depth of cut. The 1617 is only 2 1/4". I'm sure my Hitachi M12V and V2s don't go that deep. I needed to make some deep mortises a couple of years ago on a door frame and I switched to a longer bit after going as far as I could with a carbide spiral. I would have done them on my drill press with the mortising attachment I have for it if I could have but it would have meant standing some pieces on end and I'm not sure if I have the height for that so I was stuck with a router. If you have a choice then either buy a mortiser or get the mortising attachment for your DP. It's a much better option in the long run. If you can't do that and you are in production mode then I would set up two routers both with the same guide bushing and one with a longer bit. Do the initial mortise and then drill out most of the remaining waste with a hand drill and finish the bottom and sides with the second routter.
You should copy and paste your tool list into your profile so it is there permanently. I needed to know if you had a drill press so that I could suggest the mortising attachment. It's something we may need to refer to from time to time.
