I need help replicating the window molding in the attached photo. I need at least 20ft. Also any hint on what type of wood that is.
Rod
Rod
I did not understand any of thatSomething I haven't tried ........ but couldn't a profile be made ........... and using the Tiling method .............. a ......... now hold on ........ I know it's a wild idea ......... a CNC put it out??
1... Perfect!!! and yes it can... this method is called built up..The molding is for a historic property which needs to stay authentic.
The width of the molding is 5-1/2" [ie 1 by 6]
1... I was thinking it could be made in three pieces.
2... The center piece cut bevels with a table saw and round over by hand with a plane.
3... The side pieces can then be cut using the router table and standard bits.
Rod
neither did I...I did not understand any of that
I would agree with you to break it up into three pieces as you suggested...that's thinkin' outta da box...!The molding is for a historic property which needs to stay authentic.
I was thinking it could be made in three pieces. The center piece cut bevels with a table saw and round over by hand with a plane. The side pieces can then be cut using the router table and standard bits.
Rod
