Hi,
This is my first post and I'm not only a newbie here at routerforums but I'm also a total newbie to woodworking to the point that I haven't even purchased a router or table saw yet.
I have a very specific need for a project that will require making hundreds of evenly spaced dadoes/grooves and really need help figuring out the easiest way of doing it.
I'm making roughly 2' x 4' acoustical diffusers that will need to have a groove/dado that is only 3/16" wide (for undersized 1/4" plywood), 3/8" deep, and spaced exactly 1.5" apart.
I will be making at least 20 of these, and each one will have 12 grooves spaced 1.5" apart, only 3/16" wide and 3/8" deep.
I was originally going to buy a table saw and dado set but I cannot find a dado set that will allow me to cut under 1/4" wide dadoes.
I then thought about buying a thin kerf blade and regular kerf blade and just stacking them to make my own cheap dado set but I'm having a lot of trouble finding two blades that equal exactly 3/16" to fit my 1/4" nominal plywood.
To help visualize what I'm making (since I cannot post links yet) just think of slatwall panels only instead of t-shaped grooves they will just be flat/straight grooves and instead of the slats being 2.5"-3" wide, they will only be 1.5" wide.
I've looked at several home made exact width dado jigs for a router, but it would take forever (and probably wouldn't be very accurate and I do need accuracy for this project) to measure and line up 12 grooves per board and then do it 20 times or more... That's a minimum of 240 measurements, unclamping, clamping, etc.
I want to make a jig that will allow me to cut perfect 3/16" wide, 3/8" deep dadoes/grooves spaced 1.5" apart and make it as easily as possibly and fool proof as possible since I have no experience.
If only 1/4" plywood were really 1/4" I could use a dado blade and table saw and have no issues, but alas, I really need some ideas.
The only good news is that I don't need it to be adjustable because I'll always be using the same plywood and I'll always be making 3/16" grooves, 3/8" deep, every 1.5" apart. The bad news is I have no idea what the best tool to use is or how to design this for a finished product that will be roughly 2ft x 4ft with 12 of these grooves per board.
Thank you so much in advance for your ideas, help and support. I've spent about 30 hours in the last week researching this forum, YouTube videos, and Google, and have come up with many ideas, but none of which I really know how to engineer and build properly. I finally landed here, made an account, and hope to become a master at this and one day look back on this, my first post here, and chuckle at how inexperienced I "was" and see how far I've come.
--Jason
--Jason
