I'd use a sash bit that gets you close, then replace all the trim on all the windows that are close together. If the shape is close, only you will notice it.
You could use several bits, and cut the basicshape with an angled blade in a table saw, then use a roundover on the tip, and a cove bit for the outward curve. But I would only do it that way if I were only replacing the sash in one window.
