Recently I've cut 2 clocks using 1/16" end mill for detail and 1/4" end mill for milling larger clearance using 0.125" depth. I used the "Auto Tool Zero" function in Mach3 in the same spot for both tools. On each clock, the 1/16" end mill cut slightly deeper than the 1/4" clearance. It's enough deeper that there is a visible outline around each item in the clock. Since the depth of cut stays constant on both cutters with any change, is there a way to correct for this problem? I'm using Aspire 9.512 and Mach3.:help:
