Hi Suej, and Welcome Aboard. If you will check some of the previous posts on this subject you will find many recommendations. I think the most important thing is to determine what you want to do with your new router. It's intended use will dictate what style, HP, etc. would be "
best". Then too, there is the question of money. How much do you want to spend?
If it were me, I would choose Porter Cable or Hitachi, 2 1/2 -3 1/2 HP, Variable Speed, Plunge Base. Routers of this size come with either seperate collets for 1/4" & 1/2" or with a split sleeve to reduce 1/2" to 1/4". If you are going to do raised panels, you will need the variable speed and the higher HP. Either of the above brands will adapt easily for table mounting. A good set of 1 1/2" guides and base plates are accessories I'd recommend as well.
Check out
www.oak-park.com for the router bases and guides, also
www.leevalley.com for some less expensive guides.
Hope this is helpful.
