I saw a reindeer template on WWGoA that seemed simple enough so I downloaded it, printed and traced onto a 2x4. The video showed how easy it was and said it used a 3/16 blade with 10 tpi. I couldn't find that in the local box store but did want a new blade as I still have the original on my bandsaw when I bought it, used, and have used it for a little bit of aluminum, so figured a nice new blade would make it easy. I ended up buying a 1/4 inch with 15 tpi. I new this would probably take a little longer cutting so figured I would just take my time and it would be fine. Well, I'm getting frustrated and the blade is twisting awfully bad. I can't seem to keep it straight. Do I need a thicker blade? Is this one just not sharp although it is new? Just a no name brand from Lowe's I think. I kept adjusting the tension more and more and that really didn't seem to help, the blade deflects from front to back and twists so having a heck of a time. Any help would be appreciated. I suspect I need to adjust everything to be just right, but is my little 9 inch delta just to small to resaw a 2x4 in the long direction? I"m not opposed to get a nicer one as I got this used and had to replace the gear that had broke. About $30 and some time invested.
