rough out the gear really close...
attach the blank to the template..
use a burr to clean up the blank..
That is a really nice website and thanks for that. Also, some of the gear work was done by drilling the base of the gear slot an then using the either a scroll saw or band saw to remove the material to the drilled hole. Suddenly I see this getting easier and maybe after all these years I will finish this wood gear clock.I guess you've probably seen Mathias' site: https://woodgears.ca If I recall correctly he uses a band saw but there's probably a lot of useful info, including his gear template generator.
I believe there should only be X amount of teeth in your wood blank. It's no good if the sawdust is trapped in the cut. The non-pin blades might have more types available. On thicker wood a skip-tooth blade might be better. There's also blades (crown-tooth) or (reverse skip-tooth) that have the teeth going in opposite directions on either side of your material - that helps reduce tear-out.
I think that I would cut a circle for the top of the teeth, then cut them. Drilling the booth bottoms might help... then cut into your drilled holes.
The best place to learn the right way and the wrong way, unfortunately.....I think the best place to start when you want any type of information is Youtube.
so painfully true...and the wrong way, unfortunately.....
Thanks for reminding me about youtube! I've seen good things there and bad things there so I always keep that in mind when I watch them.so painfully true...
and if you lack the experience to tell the difference from good and bad???Thanks for reminding me about youtube! I've seen good things there and bad things there so I always keep that in mind when I watch them.
I'm new to this scroll saw stuff so please go easy on me -- when you said "20" scroll saw" all I could think of was a scroll saw with a 20" long blade! What is the 20" measurement for? Is it the table size?I've done so much scroll work it would make your hair curl lol. first is use the attachment for the pin less blades, depending on how thick your wood is is what size blae you use, so 1/2 in I'd go with #5 or less blade, the lower the finer work you can do, but #5 should be good for gears, get one of those magnified light things, help a LOT to see your lines. Use the clamp thing to keep the wood on the table if your saw has one, keeps the wood from chattering , also use reverse tooth, helps with less sanding. try different blades and sizes till you find the ones you like. The pin less will help with any fret work you do on your gears, pain getting the pin through any hole you drilled. go slow at first and keep the machine at about half speed or more, the slower it goes the more it chatters unless you use super fine blades.
I use the dewalt 20 inch scroll saw, mid range. not to expensive but a nice machine.
Oh make sure your table is square to the blade so have a small square available.
It is the throat depth front back to the blade. 20" saw will cut to the center of a 40" pieceI'm new to this scroll saw stuff so please go easy on me -- when you said "20" scroll saw" all I could think of was a scroll saw with a 20" long blade! What is the 20" measurement for? Is it the table size?
Thanks to you guys for explaining that to me. At first all I could think of was some huge scroll saw.:grin:It is the throat depth front back to the blade. 20" saw will cut to the center of a 40" piece
