Hello,
Being a newbie to CNC this forum has been my lifeline. Over the last few weeks I have kindly been given lots of help in order to get me up and running. Unfortunately I am still having problems with the PlanetCNC electronics. I have been in contact with PlanetCNC support, which has been a slow moving process. My fear is that they are running out of ideas of why I am still dead in the water. Although I do not want to spend more money to go a different direction, I also do not want to be faced with this same problem weeks from now. I have been researching Mach 3 setups with a USB. There are currently some sales for a few more days. I would appreciate some feedback from these two different kits from Sainsmart.
The first kit has a 4 in one driver.
TB6600 4-Axis stepper motor driver board is equipped with Toshiba TB6600HG driver chip and it can be driving 4 motors at the same time. It's suitable for NEMA17 or NEMA23 stepper motor. It has a 12V power supply which can be used for MACH3 interface board or CNC controller. TB6600 has large driver current, smooth running, quiet small volume with convenient installation. Its high performance is suitable for making CNC machines and other automation equipment.
USB controller board comes with Kit 1 and Kit 2. It's easy to use with strong anti-interference ability. You don't need to install any USB drivers, then it can be used after being plugged in the computer, suitable for all versions of Windows. USB controller board support MACH3 various versions of software and it can be used for making engraving machine control system.
5-Axis parallel breakout board comes with Kit 3 and Kit 4. Like the USB controller board, it also supports MACH3 and other computer software and of course supports parallel port control. This can control up to 5 stepper motor driver. It is easy to tell the input status with LEDs. It can be powered by 5V USB power supply or external power source.
Stepper motor
Model: 57HS76
Number of phases: 2-phase
Number of lines: 4-wire
Phase voltage: 3.08V
Phase current: 2.8A
Resistence: 1.1Ω
Inductance: 3.6mH
Torque: 1.89N.M(270 Oz-in)
Shaft Diameter: 8mm 0.3inch
Axial length: 21mm 0.8inch
Side length: 57mm 2.2inch
High: 76mm 3inch
Weight: 1100g 38.8oz
Switching Power Supply
the range of AC input voltage is changed by the switch
high-efficiency, high reliability
100% full load burn-in test
Protections: Short circuit / overload / over voltage / over temperature
built-in cooling DC fan control
Working frequency is 25 kHz
Input Voltage:110V/220V
Output Voltage:36V
Output Current:9.7A
Output Power:350W
The second kit is similar but with 4 driver boards.
Mach3 4 Axis USB CNC Controller Card 100KHz
Support for 4-axis linkage, you can connect four stepper motor drives or servo drives;
Maximum step-pulse frequency is 100KHz,which is suitable for the servo or stepping motor;
Support automatic probe tool
Support Emergency input
Support for limit switch
Support for connecting electronic handwheel
Need use external 24V DC power supply to isolate USB and external port, and to make the system more stable.
Have 0-10V output port, you can use mach3 software to control the spindle motor speed.
4 general-purpose inputs, you can connect the limit switch, estop switch, probe switch, back to zero and other device
4 general-purpose isolated relay drive output interface, can drive four relays for controlling the spindle starts, forward rotating and reverse rotating, pumps and other device;
1 status LED, indicate connection status on the board.
TB6600 Stepper Motor Driver
1.DC power input type:12V~40V;
2.Output current:0~4.5A, stepless adjustable;
3.Mircostep:1,2,4,8,16;
4.Automatic half current function: half or full current can be Selected through the switch;
5.Protect form : Overheated protection, over-current protection;
I/O Ports:
24V+
C power positive pole
GND
C power cathode
A+ A-:Stepping motor one winding
B+ B-:Stepping motor other winding
CLK-:Stepping pulse input+5V (Rising edge effective , rising edge duration >10μS)
CW-:Stepping motor direction input, voltage level touched off, high level foreward , low level reverse
ENA-: motor free
+5V: Signal common terminal
Stepper Motor
Model 57HS76
Number of phases 2-phase
Number of lines 4-wire
Phase voltage 3.08V
Phase current 3A
Resistence 1.1Ω
Inductance 3.6mH
Torque 1.89N.M(270 Oz-in)
Shaft Diameter 8mm
Axial length 21mm
Side length 57mm
High 76mm
Weight 1100g
Switching power supply
Input Voltage:220V/115V
Output Voltage:24V
Output Current:10A
Output Power:250W
There is a similar kit to the one above that has ST-M5045 drivers for a little more in cost
I know this is a hefty post, thanks for the help
