Hi,
I'm new to the CNC community and shopping for my first CNC. I'm semi-retired and my goals for the machine are intricate artistic/design based profiles/carvings in 2.5d and potentially 3d as I learn more.
I'd like to be able to sell enough of my creations to pay for the machine and maybe a vacation or two a year after I learn my way around it and start producing, so efficiency is a factor.
Material will be hard and softwoods, with no anticipation of metal.
Size- I like the idea of 24x24, but would probably be fine with 13x24 unless I really loved the experience of CNC and wanted to get more ambitious.
My workshop is limited- it's the only available space in this city house, it's a converted bedroom, and it's on a 20amp circuit with 110 V outlets (that it doesn't share with other rooms).
My budget is around 5k.
At this point I've narrowed in on the Shark 2 and the smallest Probotix.
I like that the Shark 2 seems to be a larger company that sells to hobbyists and could have better support. It's a bit small, but they offer a 1.5kw 110v spindle that would be 'plug and play' with the system.
Conversely, the Probotix is better sized and has a tool length sensor option which I like. But its only spindle option is a 2.2kw, which would basically require me to have a 220V outlet added to the room (their rep suggested a step-up converter but for a 6 or 7 hour session that makes me uncomfortable).
I'm coming from experience in sketchup and would plan on using VCarve either way.
I want to use a spindle because noise is a real concern for me, and that, as well as reviews have pushed me away from options like the Sharpeoko or the Stepcraft (which has a spindle with a tiny 1/8" collet).
Does anyone have any advice that could help me make this choice?
Or tell me I'm overlooking something or another?
Or does anyone know of a 1.5kw spindle/VFD option that would be compatible with the Probotix without soldering wires like a Huanyang VFD would require? (I have no electrical experience and really want to go with options that are 'plug and play' for electronics).
