1 - 3 of 3 Posts
Discussion Starter #1
hi here i send something am trying do like you can see dont cut good can anybody help see the picture i have a small cnc and am using aspire and mach 3 i did change the tool put it gave me the same probleme thank you
It looks like one of your stepper motor couplings is loose. Check all the screws on the machine are tight.
Check that first. If it doesn't fix it we can try something else.
What type of machine is it. Also is it a valid version of Aspire or not?
Bill
I think you need a higher quality source image. I can see the same problem in both the image and the reproduction, but then I also see some slight fuzzing of the routed reproduction which a light sanding should remove. With CNC routing - Garbage In = Garbage Out
Charley
1 - 3 of 3 Posts
