Hi rn111
Here are some snapshots of the jig I use when I put in the pockets holes for the hinges.
I also use T-Bolts to hold the jig to the drill press they are quick and easy to switch out jigs on the drill press.
You can get a T-Slot router bit if you want or you can use clamps but the jig must be in the right spot and stay in the right spot on the drill press table.
You also will see a setup block in the snapshots I use it to set the jig up ,once it's set just pop in the frame and clamp it down and drill the holes, I almost aways drill the holes after I have the frame(s) done and I also keep one around just to check the setup b/4 I drill any new holes.
Note the holes on the back side and under side of the hole, they are need for the chips, from the cut and you will have many of them from a 1 3/8" hole 1/2" deep, you will need to stop from time to time and clean them out or they will change the setup.
Note about ** rubber glass retainer
In the snapshots you will see a error in the corners of the frame ,the rubber retainer is not cut right on a 45deg.and it's a bit short from the corner, so I made a jig to fix this type of error.
In the snapshots you will see a door frame with brown rubber around the inside of the frame this type of frame is for a glass door but I had a hard time cutting the 45deg. ends to fit right, I did not fix the one in the snapshot because I wanted to use it to remind me of the error,plus it needs to be a 1/8" longer than the true size.
This rubber retainer fits into a 1/8" x 5/16" deep slot in the frame and it works great to hold the glass in place without any glue or other fastners.plus you can take it out if the glass needs to be replace.
Here's a jig I made to cut the retainer at a true 45deg. cut.see below..
Hope this helps a bit.
If you need more info just ask
Bj
