1 - 18 of 18 Posts
Discussion Starter #1
Is there a fuse?
I haven't used my router in 20 years and this morning tried to route out some 2x4s. The first two went through fine, then hit a knot (I'm assuming) and the router died.
Help!
Thank you.
Super Moderator
John
Hello and welcome to the forum.
You need to give us a name of the router and model number.
They are all a little different
Welcome KBC. I've never seen one with a fuse. Does the router have soft start or speed control? If there any capacitors in those circuits they may have failed. Apparently they do much better if charged up occasionally. It's also possible the brushes gave up. That's a much cheaper fix if you can find the parts.
Reactions: KBC
Super Moderator
Welcome aboard.
Years (decades) ago, I was routing with my Craftsman router (1980's model). Suddenly it just went silent. I took it to Sears and the guy said it would cost more to fix it than to buy a new one. :surprise::frown:
So, I did.
Discussion Starter #6
That's probably my solution, too, but I just wanted some input from someone with a more educated brain than mine.
Thank you.
Welcome to the forum...
Well some of the parts are still available, including an armature for only $30. Brushes and brush holders are still available too. I didn't see anything in the parts listing that was electronic so there might be hope for it. You need to diagnose what precisely is wrong with it. Since there are no electronics that narrows it down to switch or wires (as in a broken one), brushes, or armature. If you have to pay someone to fix it it probably isn't worth it though as that was a pretty cheap router to start with. RYOBI ROUTER Parts | Model re175 | Sears PartsDirect
Reactions: jj777746
Premium Member
Is there a fuse?
Help!
Thank you.
Did you check the breaker, meaning the house breaker ?
Is there a fuse?
Help!
Thank you.
see if the brushes are at fault...
Reactions: jj777746
Ross
Super Moderator
Ah Ha! The vast and unpaid research department comes through again!
Super Moderator
And again! :smile:
I think Stick and I should stop until we get at least double what we are now. (What does 2 x zero = ?):laugh2:
Reactions: MT Stringer
zzzzzzaaaa ZOOOOOOMMMMMmmmm......
Theo
Welcome aboard.
So, I did.
Ah, you should have opened it up. I've got one of those old Craftsman routers that died. Opened it up, and turned out one of the wires was a tad shorter than it should be, and the solder at one end had given way. Problem solved.
Perhaps the attached circuit diagram will help troubleshoot it or at least take the sting out of a bad situation.
Reactions: Wildwood
1 - 18 of 18 Posts
