I'm starting a new project that I can actually show pictures of, so I thought I'd sort of "blog" the project as I go. Feel free to ask questions or give suggestions.
The project is to make a lap tray to hold the Apple's "magic" keyboard and trackpad. I want to have them in roughly the same orientation as they would be in one of their laptops, because that is what I am most accustomed to.
The reason I am making this is because I like to use my TV as a computer display, and I want a keyboard and trackpad I can use while I'm sitting on the couch. The Apple keyboard and trackpad are roughly the same as what is found on my laptop, so they were the obvious choice.
The prototype I have been using for a few months was made from pink foam board, and I routed it out using a hand held router and a crude jig with sliding gantry. Then I surfaced it with a layer of fiberglass to make it rigid. It has done it's job; it has proven that the general design and concept works.
From the beginning I have been wanting to make this out of carbon fiber. Why? Because why not? But seriously, it is more experience for me with the whole digital design process, and it will give me more experience designing composite parts.
Below is the CAD file I'm working with (Rhino). This is the idea I have been playing with, and at the moment I just want to make the part on the CNC to test it. I am not sure what the correct tolerances are, the correct depth, etc.
There are a few details that may stand out. There is a recessed area in both cavities--that is meant for velcro to hold the keyboard and trackpad down. I thought it would be a good idea, but I haven't really needed it.
Also there is a cut-out on the back edge for the keyboard, and a bit of a ramp along the back edge of the track pad. These correspond to the antennas on both devices. Carbon fiber is conductive, so it will block radio frequencies. So I am expecting that I will have connectivity issues if I do not create clearance in these areas.
Also, I drew a flange extending around the base. I added this because VCarve didn't seem to recognize the vertical sides of my part. So I made a flange larger than the actual work piece, so now the program will remove the excess material around the permieter.
First attempt to machine. I made 3 tool paths, which is the process that has been working really well for me. I start with a rough pass using a 1/2" ball nose cutter, and within ~.050" of the final surface. Then my second pass is a "finish pass" with a 1/8" tapered ball nose, but I use a large step-over and leave 0.010".
When the second pass is done, I coat the part with a thin, fast setting epoxy. I put it on pretty thick, leaving excess resin on the surface, because I want the surface to be saturated. The excess resin machines off on the final pass, so I'd rather have a little extra than not enough.
The final pass then uses the same 1/8 tapered ball nose cutter, but I use a much smaller step over. And I cut right down to the final surface.
For this project, I decided to try using the vacuum table. I thought it would work fine, and I liked the idea that I would not have any trimming when it was done. But unfortunately, the MDF started to curl while the program was running, and the vacuum couldn't hold it down. The part was ruined, but fortunately the bit didn't break. The picture shows the damage--this happened part way through thte 2nd pass.
(I did face off the bottom first, so it it was flat. But like all kinds of wood stock, there can be internal stresses that show themselves when you start cutting them.)
Next step: I want to try to use the vacuum table again. I know MDF is a low quality material, but I want to see if I can make it work. I want to glue up a block of 2 layers of MDF like I had before, but I will make it over sized. And when I machine it, I want the excess material on the perimeter to stay connected by maybe .030". I can still separate it without too much difficulty, and hopefull the extra material helps is stay held down.
