You might try the Micro Mesh Discs on a ROS after you let it dry for several days. The trick is to use all 9 discs and the last one the 12000 grit disc will make a mirror finish like a Porsche fender. You can see yourself in it.
https://www.amazon.com/MICRO-MESH-NO-HOLE-SANDING-COMBO/dp/B000H6JDDC
