boomerang said:First post - finding my way around
My guess to the screws... for fine adjustments...Kevin said:That looks interesting! What are the screws for that are on the end?
Paul - The UHMWPE (split) Fence (faces) are attached to an aluminum angle - the real fence. Check out the other pics.paulcomi said:Is that plastic material rigid enough to not flex when used as a fence?
I made the Table from 1-1/4" MDF and laminated both sides. Phenolic plate and inserts are from Woodhaven.com - they also provided the template for the cut out. all worked out very well. I also have a Triton Router (Oz design) which allows me to change bits "above table".rout-on said:Hi Boomerang; Not sure if I can see all of the picture...but is your table made of that plastic material as well.Looks impressive.I have some of that material I plan on using when I get my plate for my router...............Looks like you may use some big cutters there.Did you try making various inserts of that plastic as well.saw it done before...cuts out a profile of a preferred bit for zero clearance.....LATER,Dave.
Snowshoe said:So how do you like that Triton router? Have heard some good things about it.
I know I'm about a year late to ask about this, but I'm a beginning woodworker who has just discovered this resource. Boomerang: Your fence looks really spiffy. Is that a fine adjustment knob in the back there? Do you have plans for this fence set-up or can you tell me where to get them? Also, where did you get the aluminum angle?boomerang said:I hope they attach...
