I need to build a little "cabinet" for the mudroom. I am thinking I can make it of 3/4"plywood. To fasten it I am thinking I can just cut slots, as you would with a biscuit cutter, by using a 1/4" straight bit and going in 1/4" on each piece. I then take a piece of 1/4" plywood and insert it with glue etc. and clamp it. I think I've seen this technique used someplace. There would be shelving inside the "cabinet" to add rigidity.
I am not a skilled woodworker, even though I have some nice tools. I once took an aptitude test and I scored in the 98's-99's for reading, writing,creativty etc. but in the 3's and 5's in manual dexterity. Took me two days to wire a drycell to a doorbell to make it ring. HA! See what I'm up against boys??
