$209 seems a little steep for a glue gun for someone who is unsure of their likely uses. Looks like a number of decent ones are in the $30-$50 range. I'd buy this locally so you can get a stronger sense of what you're getting, how it feels, direct comparison of features.
So go find it and tell us what you use..My wife has one somewhere from her crafting days. I don't see a whole lot of use for one in the shop. Most of the time double sided tape does the job for me. Mostly I was reacting to that expensive one Stick suggested.
no I didn't...Stick you missed plug-in or battery powered
I use mine occasionally when I need a quick bond that can be taken apart later or to hold something while a better glue hardens. For example when I make extra table saw inserts I hot glue the factory one to some mdf and use a pattern bit to route it to size. Same goes for quick and easy jigs. Hot glue them together and if you need extra hold add regular glue or brads or both. Get one and use it for a few things like that and you’ll probably start seeing other possibilities.
I've had a Craftsman glue gun for don't know how long. Cost was probably around 20 bucks when I bought it. Nice thing about it, is that it came with a stand and the power cord can be disconnected when in use. You do have to plug it back in after the gun begins to cool down or just leaveit plugged in!!
With the addition of grand kids to the clan, it see's more use than ever, repairing dolls, cars, shoes and all manner of toys. Works very well in most applications.
Couple of down sides. Application nozzle usually over applies the glue. Glue typically turns yellow in time. Neither of which are a big deal considering what I use the stuff
for.
Its all about the glue sticks that you use!!!!!! Usually a couple minutes to heat up and then to cool down. All in all, not a bad addition to any shop.
I have one from Amazon that has worked very well. It has two temperature settings, heats quickly, doesn't drip, and the long nozzle makes it easy to get into tight areas. Best of all, it's only $25.
https://www.amazon.com/Nozzle-Premi...ts+and+Crafts&qid=1556980531&s=gateway&sr=8-1
