Hello,
I am a newbie to woodworking.
I made a template by cutting a complex curve into plywood. The curve can be followed by a 12mm (1/2") dia cutter.
Now I want to use template to cut the curve into a 50mm (2") thick piece of softwood. The softwood has already been cut to within 2-3mm of the profile using a band saw.
I can see two ways of doing this:
1. Use a trim bit with with a bearing at the tip. Having a tip bearing would be good for stability as it would stop the cutter tilting into the softwood. However I would have to cut the whole 50mm at one time and having a cutting edge that long concerns me a bit.
2. Use a trim bit with a bearing at the shank and quite a short cutting edge. I could make he first cut following the plywood profile, then make a second cut following the profile I had just cut and so on until the full 50mm was cut. The snag with this is that I would need a cutter with a long shank to be able to reach the full 50mm and I have not found any.
What is the best and safest way to approach this. is there another way, are there trim bits with long shanks?
Also is it better to do this on a table or with a hand held. At first I though a table but perhaps holding the heavy router by its handles and having the wood in a vice is actually a better option?
