Often times I do a dado cut with the router and find circumstances where due to expansion of the wood or whatnot the cut is under the width of the wood often times about 1/16 of an inch under.
I could pound the wood into the joint, but you can obviously damage the piece in doing that, or running another pass with the router to get that width is tricky since you could easily create a dado that is too wide.
Any suggestions on that?
Thanks...
Thanks...
