1 - 11 of 11 Posts
Discussion Starter #1
My dust collector is about half full or you might say half empty. :wink:
When should I empty it? I am thinking it's ready now.
If you have a bag to empty I would. Mine has disposable plastic bags on bottom so can wait a while longer but still do not want it too heavy.
You are probably getting to the point where the cyclonic action will start being affected.
Premium Member
I've found that half full is a good time to empty...if only because you can shake alot of the top dust into the bag,,let it settle down then its also much easier to disconnect and dispose of...
Mine is a 32 gal garbage can and when it gets about 2/3 full I empty it. I can feel a decrease in airflow about that time. I have forgot and left it until it was right to the top before and did notice an increase in airflow after I dumped it.
One time a long time ago I wasn't paying attention until my airflow dropped drastically to almost nothing and when I checked the collector bin was full and so were the canister filters. What a mess to clean up. Needless to say I put a sensor on the bin to set off an alarm when the bin is full.
I let my DC collector bag get nearly full before emptying, maybe I don't see a noticeable drop in suction because it's a 1.5 hp motor and I also take the upper 1 micron filter bag out and beat the crap out of it at the same time and hose it inside and out at least once every summer. I don't know the volume of the collection bag but it's 45" long with a 24" diam., it holds a lot of dust and chips and weighs a ton. If it is PT free I store it outside in the garden for about a year then mix it into the compost and garden soil.
Premium Member
I think it depends a little on how its set up. If it has the conical setup, I think it will work ok until fairly full, But if it is an in-out canister, then half way full is about the right time to empty. It is amazing how heavy it gets. I have a drum container and just bought some clear plastic bags to tape tight over the drum so when I empty it, the dust doesn't go flying.
Discussion Starter #9
My DC is a Grizzly 1 1/2 HP model. I did empty it yesterday and I am glad I took it outside. The dust from the upper bag got all over everything even though I beat it half to death. :wink: Cleaning it up was a easy, I just fired up my leaf blower and spread it over the yard.
Hawkeye10,
It won't learn nothing if it's only beaten half to death.
I hang mine from the swing set out back and pretend I'm interrogating, (beating) and evil puppy abusing animal terrorist who needs to learn something about being nice. When I smack it, it reminds me of sawdusty smoke signals aimed at the ground.
I begin my ritual with the memorable demand from the Nazi interrogator in the "Cheech & Chong skit, "Sign ze papers oldman!" then I commence ta smackin.
"I put a sensor on the bin to set off an alarm when the bin is full"
Herb, you have my attention! How did you do this?
I used a garage door sensor light set up between the cyclone and the dust container, cut a hole and put a plastic window for the light to shine thru, when it is blocked it sets off a strobe light in the shop. In my old set up it was in the side of the container near the top.
Also do like Tom and put a plastic bag into the dust container and just tie the top and throw it into the garbage. I put a piece of formica bent around the insde of the can to hold the empty bag from being sucked into the cyclone.
1 - 11 of 11 Posts
