ejant said:
I have found if not sure start with shallow passes and get the feel for the material/bit and how they are reacting together. Then adjust accordingly.
That's dead-on advise :sold:
As an example of it, I was cutting a 28" long slot through a piece of finished 3/4" particle board today (It's the adjustable pivot point slot for a band saw circle cutting jig).
The first plunge cut with a 1/4" spiral up-cut bit seemed to go rather quickly so I tentatively began a full-depth route. I went quite slowly, but it just didn't seem "quite right".
I changed over to making an 1/8th- deep pass and WOW! The bit bore across that material as if there were no tomorrow. So shallow cuts it was.
I think I was finished and cleaned up after making several passes in less time than it would have taken me to make a single dep pass. (And I'm sure the router bit liked the several-passes way of doing it better as well
So yeah, playing it by the feel of the material is the only realistic way to go. Some stuff just cuts faster and cleaner than other stuff -- but you aren't going to know 'til you get into it
