To figure the parts to the drawer I first need to know what type of joinery your going to use.glassguy1456 said:
Having said that for this example, I will assume we are using a simple drawer construction with a rabbet joint on a sub-front, dado for the back and the groove for the bottom. The drawer front will mount on the sub-front after the hardware has positioned the drawer.
All rabbet, dado and groove joints are cut to a depth of 1/2 the material thickness. This is because two halves equal one material thickness and the amount you need to minus from the overall width of the drawer is then one material thickness to make the joinery work. For this example the groove is set in 5/8", which determines the width of the back. Note: the groove position is determined by your hardware.
Example: Drawer sample: 4" X 12" X 24"
The overall width of the drawer is 12", depth is 24" and height is 4", the thickness of the drawer sides, sub-front and back is 1/2": You need to minus 1/2" from 12", which equals 11 1/2" for the length on the sub-front and back. The width of the back is determined by the 5/8" groove position.
Parts list is as follows:
width Length Thickness
1 - sub-front 4" 11-1/2" 1/2"
2 - sides 4" 24" 1/2"
1 - back 3 3/8" 11-1/2" 1/2"
1 - Bottom 11-1/2" 23 3/4" 1/4" Plywood
It is now your turn...
Make the list of materials for the following drawer: 6" X 14" X 24"
Then make the list of materials with 3 other drawer sizes of your choice.
