1/2" is probably a little thick but I wonder if you can clamp it down and maybe use a heat gun to help it lay flat on it's own? Post some pictures when you get started on it and I'm glad to hear you're feeling better!! Joe.18 x 23 3/4 x 1/2 inch...and it is not flat! <a href="http://www.routerforums.com/images/smilies/frown.gif" border="0" alt="" title="Frown" ></a>
+1 on zero flutes!I use zero flute bits for acrylic but haven't tried to cut HDPE. I wonder how those would work? They sure work good on acrylic.
David
Regular bits can cut acrylic fine. They just don't clear chips as well. If they are sharp, they will cut cleanly. Try climb cutting.Regular bits will leave tear out on acrylic, but the "for plastic" bits leave a smooth edge.
I try and learn something new every day and this is early enough I can go back to bed!! :grin::laugh2:
They are "O" (oh) flute, not zero flute.
Let us know if it works!I like the idea of using a heat gun.
Thanks Harry. I think I will make one out of scrap plywood to see how it looks in place. It will sit on the shelf of a Blackstone 36 inch griddle. My thinking is to countersink and glue some magnets underneath so it will stay put. The outer edge will hang over the shelf by 2 1/2 inches, thus providing a larger work area and a place to set my drink!Cutting sheet plastics of all kinds I've always used the table saw and to clean the edges of Acrylics I run a gas flame along the edges.
and nick sensitivei usually dress all cut edges with a 1/16" radius round over bit. The untreated edges are like a razor blade.
So true!and nick sensitive
HDPE doesn't accept glue too well. Not much sticks to it for any length of time. The only thing my HDPE distributor says works is Spray 77. Forget who makes it. Maybe someone here may remember the manufacturer.Thanks Harry. I think I will make one out of scrap plywood to see how it looks in place. It will sit on the shelf of a Blackstone 36 inch griddle. My thinking is to countersink and glue some magnets underneath so it will stay put. The outer edge will hang over the shelf by 2 1/2 inches, thus providing a larger work area and a place to set my drink!
Since there are two shelves, I may have to abandon the idea of cutting up the plastic cutting board for now, and go with solid wood. I know there is heat involved, so I have a plan to shield it also. That will come later. One project at a time.
Edit: The two slots are for scrapers or spatulas to fit in.
