How to route 10" square in tabletop?
6924 Views 16 Replies 6 Participants Last post by  Mike
I wanted to route a 10 inch square to a depth of 1/4 inch on a workbench. Having never done anything like that I had some problems. I ended up using a lexan plate mounted to my Bosch plunge router which was not ideal. My first problem was that the plate was not large enough to have all four sides remain on the top ( non routed) surface - one corner would be unsupported as I moved the router to the opposite edge resuting in some "divots" in the bottom. The second problem was the lexan tended to sag when the router was in the middle of the square resulting in a cut deeper in the middle than the sides.
I got the job done but wondered how the "pros" would do it so the bottom would be glass smooth and even.
Is there a better way to do this other than buy a big expensive piece of lexan?
Thanks!
Lee
1 - 17 of 17 Posts
I would suggest starting in the middle and working in a circular motion toward the perimiter. This should maximize the available support for the router.
Thanks!
Lee
A couple of thoughts for you...
Rather then lexan an acrylic sheet of let’s say 3/8" thick is very stiff and cheaper in general then lexan. (Of course if you drop it does not act like lexan.) I have a post that you might find interesting so check out:
www.routerforums.com/showthread.php?t=395
(I use it to do some lettering where the letters are left and the other area is in relief.)
You didn’t say how you controlled the cutting process, template guides or ????? but making a pass around the outside first then as another answered starting at the middle and working out is a good idea.
The third part of this is the bit you are using. It should be one that has a bottom cutting edge, a plunge type bit will work better then a plain straight bit.
Ed
Thought of a couple of other hints:
Stop and clean out the chips often and if you're using a plunge router do the plunge near the edge where more of the router is supported.
Ed
Make yourself a template which will be greater than the square size required (This will depend on what template guide and cutter you have available) Insert two rods through the base of the router where the side fence is usually attached. Approx 2-3 feet long then insert two supports either side to keep your router level and of you go
Tom
Thanks for all the good ideas.
This was my methodolgy (for good or bad): 1. used 1/4 " upcut spiral bit to define the edges of the square in two passes of 1/8" each. That worked great. Used a straight edge as a guide. 2. Switched to a 1/2" straight bit to remove the remaining center in 1/8" increments (two passes).
Comments or questions:
bmb: Wouldn't I quickly end up with only 1/2 the base supporting the router as I moved out from the center? A tough balancing job with my Bosch plunge router.
tom: I'm with you on the long rods through the edge guide holes (clever) but you lost me when you talk about two other supports. Please explain.
reible: Thanks for the info on acrylic. Also read your referenced post. Got to hunt around for one of those base making kits. I did think about using 1/2 ply for a base but I would have to make a lot of holes in it to see and I was afraid the rigidity would suffer.
I thought it wise to only take 1/8" passes but maybe I made my problem much worse having 3 depths (surface, 1/8", and 1/4") to contend with. Should I have done 1/4" in a single pass?
Thanks again, Lee
OK, first I would make the outside pass in maybe two steps the first being deeper then the second. I would make sure the cutter has a cutting edge on the bottom. Otherwise a std straight bit has only a cutter on the edges and will leave swirrely (sp?) marks. I would then go to the center of the square or about so and make plunge to the full depth. From this I would work out towards the edges in a spiral pattern with the bit at full depth and take off just a small amount of the edges as you go. You want to go so the bit cuts into the wood and does not get pulled along. As you get closer to the outside make sure you keep the pressure on the supported side.
This is a lot like when I do free hand signs except the letters are always left to add support. The larger sub base I made allows the smaller lighter trim router to work very well for me.
If you have a "dish cutter" they do a really nice job. They might have another name but it has a flat bottom and a radius on the edges so they don't dig in.
Ed
Tom
Tom have you tried this and if so what dia of rod does your router use?
I had a simular idea maybe 10 years ago with a Sear router and crs but the rods turned to to move all over the place. I then threaded the ends and tried to pull them tight in the box I had made. This worked better but I gave up on the idea. The Porter Cable routers I now have use a much thicker rod so maybe I should revisit this next spring when my workshop opens again.
If you have a working model could you post a picture?
Ed
Lee, if you need a larger base plate for a special job try making it out of 1/4" Masonite. This is far cheaper than either of the plastics. Just cut your inside clearance hole so its within your mounting screws and you will have plenty of view to see your edges. This is only a guess but perhaps you are making a tile inlay table?
Ed
This is off topic but after reading Tom idea I posted but I'm not sure it is clear what I was talking about so I did a couple of sketches. Please keep in mind this was what I tried to do but it DID NOT work well. DO NOT make one of these based on what I did but you are welcome to resolve the problems and do as you like....... BTW this was done some years ago so the details may not be as shown......
Ed
Mike masonite is something I use a lot of, because as you say it is cheap but in this case I think it would not be rigid enough. I have seen 1/8" and 1/4" do they make anything like 3/8"?????? I personal buy 4' x 4' sheets and cut chunks out for all sorts of templates etc.
But the real reason for the post is to mention that you could route out part of the opening and the cut some "masonite" and put that in the cut out area for added support while you cut away somemore of the square.....
Ed
Ed
Ed
The rods were 12mm thick the same as my side fence attachment and they were secured with the two retaining screws The supports were then added to keep the router level. A template cut-out was required the size of the square plus the difference between the cutter and Template guide. It is necessary to have a flat board to work with. The router is always at the same height and can be moved around inside the template with the guide controlling the path round the edges,
template tom said:
Ed
Pic one the rods are resting on the side of the box for convenience
Pic with the heart cut out is exactly the same as I was suggesting only the shape is no longer square
Tom
I just wanted to jump in here and say thanks to you guys for a "powerful" learning thread. This addresses a very good subject and it looks like you have come up with some very good solutions.
I am pruod to be a member of such a fine community of people with a common interest and desire to share knowledge.
Merry Christmas to all.
Bob N.
template tom said:
Ed
Thanks for the pictures!
I can see why your process made a lot stiffer support then my vain attempt with the 1/4" (6.3mm) one on the Craftsman. I checked the PC and it has just over 7mm still a very long way from your 12mm.
Ed
I think Toms idea would yield the most perfect results - and naturally it requires the most set up. The edge guide rods on my Bosch are .375 inch which is approx 9.5 mm by my rough calculation. Great photos, Tom. The rod selection from big boxes and hardware stores around me is poor. I would have to order it from a supplier.
The masonite "spacer" may be the best quick solution. Wish I would have thought of that at the time.
One layer of 1/4" masonite would sag, I believe. That Bosch is rather heavy. I do wonder if two layers would do the trick . Certainly cost effective if it could support my router over such a long span.
For info, I was inlaying a steel plate into a bench top that Kreg sells as an
accessory for their pocket hole system. Yes, I do want to make tile top inlay table soon. They seem to present the same router problem to me.
Thanks for the help!
Lee
Lee, I have used 1/4" Masonite for circle cutting jigs on my Bosch 1617 with no problems. Perhaps a good solution to the flex problem would be to glue some 1/2" strips of wood around the perimeter of your oversized base? Having a rigid edge should provide plenty of support to stop any sag. Titebond III dries quick. If you wanted to increase the thickness cut a piece of 1/8" or 1/4" masonite and use contact cement to glue the layers together. My router table top uses 3/4" plywood and 2 layers of 1/4" masonite with top and bottom sealed with Formica and a hardwood edge. I am delighted with the results. Inexpensive, vibration dampening, easy to work with.
When you get around to doing the inlaid tile tabletop, make sure you use wall grout between the tiles, not floor grout which has sand mixed in it. And you dont have to settle for white. Grout comes in many colors now, even black for a very decorative finish.
1 - 17 of 17 Posts
