Magnets with holes. Do a quick search for rare earth magnets with holes, or magnets with holes. Then you makes your choice.
Probably aluminum lolGood looking sign, John!
Is the door clad in a Ferrous metal? If not then magnets won't work.
David
That's when you affix a hook on the door, and just hang it. That or duct tape.Good looking sign, John!
David
I don't understand? do you mean NON-ferrous?Good looking sign, John!
David
aluminum clad is common here...I've never seen a metal clad door other than steel, not counting brushed ss.
Not saying someone somewhere doesn't make one but it'd be mighty rare.
Nothing to recommend Aluminum over steel other than being rustproof.
Nope. Meant it just as I said, Herb. If it's not clad in a ferrous metal then magnets won't work.I don't understand? do you mean NON-ferrous?
If it is a steel clad ,magnets should work embed into the back of the plaque? But thru bolt into an insert might be better anyway.
I stand corrected, I mis-read your post,Nope. Meant it just as I said, Herb. If it's not clad in a ferrous metal then magnets won't work.
David
