Hi DW wilson44
As you know doing a kitchen remodel can add up to big bucks but if you know how to cut some of the cost you can save big bucks also.
The best way is make your own cabinets from the ground up and doors with the two videos below you will know many of the shortcuts.
The videos cover Horz.bits but the same thing is true for Vert.bits just a bit cheaper.
The bits I recommend are listed below...
You will also see a bit set to make the door frames below.
http://www.grizzly.com/products/h5564
this one comes with a Horz.panel bit,3 pcs.set.
I do Recommend you get both below videos below.
Arched Raised Panels Made easy
Cabinetmaking Made Easy DVD
You will get one of them FREE when you place a order on line when if it's over 20.oo.
FREE one=it's in the VHS....format...
Raised Panel Bits - Vertica
http://www.sommerfeldtools.com/products.asp?ID=118
on sale at 38.ooea.
Plus this set below T&G set.
http://www.sommerfeldtools.com/products.asp?id=202
http://www.sommerfeldtools.com/specials.asp
I made a jig to make raised panels quick and easy, see below
http://www.routerforums.com/showthread.php?t=2725
hope this helps
Bj
