... with a new shop vac.
You're invited to the wedding. Gifts are not needed. Just bring ideas.
You see, this love story started when I finally broke down and bought a Dust Deputy.
(Quick DD Review: The heavens opened, melodious harpsichord music accompanied angelic cherubs singing harmonious melodies, and the Pearly Gates sparkled in the brightness of the dust free shop vac filter when held to the light, while an entire bucket full of sawdust was sent down to Hades for kindling. The DD is THAT good.)
So the first question is... what took me so long? Why the heck did I keep putting off buying an Oneida Dust Deputy?
I can answer this question, so as to free you up to answer the more difficult questions further below.
I put off buying the DD because I was put off by the price. $100 bucks for a plastic funnel and a paint bucket? Not gonna happen. Then YouTube sent my head spinning like a cyclone with all the "How I made a dust deputy for $1.98" type of diy videos. Naturally, just seeing the titles of those videos, whether actually watching them or not, makes a person feel like a sucker for ecxhanging their shop card for a credit card and caving into the commercially produced solution. A few years rolled by in that dilemna, but somehow I never got around to making my own 2 bit version of dust can do.
In the meantime, over the course of these years of procrastination, cylindrical pleated shop vac filters were getting pricer and pricer... and cheaper and cheaper at the same time.
Whereas I used to wait until the filters were on sale if they were priced at $6.99 each, they are now $35.99 each (30 years later).
Whereas I used to get 10 rinse out and air dry cleaning cycles out of a filter, they now fall apart after only 3 cleaning cycles.
So in the time that transpired between first learning about the Dust Deputy, to finally breaking down and buying one, I had spent over $115 in new shop vac filters. Had I just bought the DD in the first place, I'd have only spent $100, and still be using the same filter from a decade ago. Instead, I spent $215, and will have to live with a cheaper built filter that will now last the rest of my life. Dam, the DD is effective!
Now... questions for YOU to answer:
1. What is the highest CFM, highest vacuum suction shop vac on the market today that can run on single phase 120v 15 amp circuit?
The DD changes everything. I no longer need a "16 gallon" shop vac (I have three of these R2D2 tubs of plastic) and no longer need the volume capacity in the shop vac itself. Dirt goes in the DD bucket, not the shop vac. So why have a giant shop vac?
I'm looking for a 12 to 15 amp power house motor housed in a small, tall container, sized only for holding a hepa filter having the largest available surface area, so as not to restrict CFM.
Bosch just recently introduced a 300 CFM dust extractor vac, but it's 17 gallons, and I think uses 17.5 amps. Their previous dust extractors were 14 gallon and 9 gallon, and used the same 9.5 amp motor that produced 150 CFM. I want the 300 CFM, or as close as possible to it, without the big canister, and without the 20 amp circuit requirement... so I can more easily split circuits with the shop vac on one circuit and a corded tool on separate circuit.
2. What type of roll around mobile cart arrangements have you seen where the shop vac is positioned directly above the Dust Deputy... so that the dirt bucket is on the bottom, then the cyclone funnel is above that, and then the shop vac motor and filter are above that?
I've seen where people put the DD on top of the shop vac, presumably because the shop vac has the greater mass constant, and to reduce tip over, they want the mass on the bottom.
I've also seen side by side arrangements, including a very elegant rendition here on RouterForums... built by the secret heir to the Rockefeller fortune, because that poster went on to build a whole shop dust extraction system out of all metal ducting, 6" no less, with a cyclone funnel large enough to split the nucleii of the heaviest atomic particles yet to be discovered by mankind. I'm not on that kind of budget... but I want to execute that kind of quality with as much creativity as the pennies randomly found on the street will afford.
Any other photos or ideas regarding my planned wedding of Dust Deputy to a powerful suction, large surface area filter, low volume capactiy shop vac will be greatly appreciated.
