1 - 13 of 13 Posts
· Registered
I'm wondering if anybody has ever used the miter lock joint to join two workpieces together sidd by side instead of at 90 degrees as the bit is designed for.
I have not tried it, but do that when I was messing around trying to learn how to use the bit that one of the things that I found and anybody else that is familisr with such a bit will recall, the cuts made with the workpiece flat on the table sure do make a nice joint when put together side by side. That is of course when the bit is set properly.
Just wondering,
Jerry
· Registered
Just wondering,
Jerry
Jerry I was just getting ready to watch this video but thought I would see what was going on here. So watch it if you want it might help.
https://www.youtube.com/watch?time_continue=5&v=vvi-6n3Fr9Y
· Registered
Discussion Starter · #3 ·
Don, that's a ggod video Don, just for your information, while the gauges that Infinity sells work well, they do require that you can see the marks on them, since I am nearly blind, I have had to find a method to set the bit up in another manner and it works extremely well, probably better than the set up gauges in my opinion.
As you know, my question is not about setting up the lock miter bit, but wodering if anybody has used them for other than the 90 degee joint.
Thanks for sending the link to me anyway,
Jerry
· Registered
Have never actually used it that way. But, like you, I've put them together like that to test my set up. That would make a very strong lamination. But, I can't think of anything I'd build to justify it when a T&G would accomplish the same strength.
· Premium Member
LIke you guys I've played around with doing that, no doubt would provide for an exceptionally strong joint, but see no real advantage to it except if the end grain appearance would play into the cosmetics of a piece....ie: using different colored wood.
· Registered
Discussion Starter · #7 ·
The issue of making an end grain cut is as easy as with a cut that goes with the grain when I use my method of making miter lock cut. I know how difficult the end grain cut can be making the cuts the way that most people seem to do it. The difficult of making the end grain is part of the reason I had to find a differenct way to do it.
Jerry
· Retired Moderator
The ridges in that orientation are short grain and therefore fragile. The glue would help with that. However, it seems like a lot of unnecessary work when a spline would work as well or better and is much easier to machine. Grooves are easy to make on a table saw and setup takes seconds. Tuning a dado stack to the right thickness can take a few minutes but the TS will cut grooves in feet per minute where a router would be measured in inches per minute.
Reactions: harrysin
· Registered
Gimmie a spline every time. Well, at least in this case. Much easier to get right and much stronger joint.
I have one of those little jigs somewhere. Tiny, hard to remember where I put it. Thanks for the video.
· Registered
Discussion Starter · #10 ·
All that I asked was if anybody and tried it, I didn't really ask an ipinion, but since
you think that the spline would be stronger and have not ever tried it, well, the best way to remain ignorant about something is "condemnation before examination".
Certainly splines work just fine and why change if you don't need to change. So, Tom you you down as a "no" I have not tried it.
Jerry
· Premium Member
Retired since June 2000
Jerry
In a word, YES. one of the first joints that I tried after buying my first lock-mitre bit close to twenty years ago was side by side on a couple of scraps. I just spent a lot of time rummaging through draws and cupboards in my shed and eventually found this test piece which I photographed especially for you Jerry.
In my opinion and that of many other subscribers to this thread, a lock-mitre joint would be overkill and unlikely to be used for joining boards compared to biscuits or continuous splines. You appear to have taken exception to members who are trying to help you. Do keep in mind that this forum has always been a very friendly and helpful one and so many of us have learned new skills from each other and been grateful for it.
· Registered
Discussion Starter · #12 ·
Harry,
I agree with everything that said, I had just wondered if anybody had tried it. I also do certainly agree with you about my often being a pain in the butte to some members. I must at the same time say how much I have enjoyed the advise that I have received. I have often considered logging off of the forum for good due my being so thin skinned ans asking weird questions that have raised eyebrows.
I'm just who I am and can't change that of coure, each of us is unique and that's a good thing in my opiion. Learning is an important part of life, wouldn't life be boring if we were to every stop learning? I suspect that the list of the ways that people learn is rather long. I have a nephew that had trouble learing in grammer school, his folks sent him to a kspecial school where they teach in a different manner and he did very well and now holds a a good position with Hulett Packard, a job that he had to compete for. He is a very bright guy, but learnes in a differ way than most people.
Jerry
· Premium Member
"I'm just who I am and can't change that of course, each of us is unique and that's a good thing in my opinion"
I'm so glad that you put that in writing Jerry because it's so very true. (Jerry will understand this)
1 - 13 of 13 Posts
