I made this patio sign out of 15lb Precision Board from InteState HDU. The material is a joy to work with because it cuts so easily and cleanly. The HDU holds fine detail well, and you can cut to a full depth even with somewhat fragile bits like the Whiteside 11º SC50 bit which has a needle-like point.
The most significant problems with using high density urethane are availability and cost. I can only get it online, and the price for a 24” x 24” x 1” is about $80 plus shipping. Needless to say, I save it for special projects. This sign blank was 8” x 24”, so the material was about $27 which isn’t that outrageous. This sign will be exposed to the weather and HDU’s impervious nature makes it ideal for this installation.
The painting was a bit tedious, but the HDU takes all paints well. The sign has a combination of water-based and oil-based paints. HDU, unlike styrofoam, is not affected by solvents like paint thinner or lacquer thinner.
So, I like it, and I would use it more often if it weren’t for the cost and availability.
