Is this because everyone is now full bottle, or, doesn't sketch up apply any more?
Thank You Rich! That gives me a bit more Grist for the Mill! Very Helpful.Boy, I use Sketchup all the time for anything involving more than 2 pieces of wood! I've used it for room layouts, yard layouts (in the simplest 2D form) as well as woodworking. I've just completed designing a horizontal router add-on to my router table and, as usual, I find that using Sketchup reveals the flaws in my design thinking well before digging through my pile of lumber. I've spent a few days refining my approach (for the router add-on) - rejecting a couple of ideas and adding a couple. The ability to create in 3D and to perform some of the same operations as you would with real wood (e.g. dados) is very helpful in thinking things through - both in terms of design and construction. So now I'm ready to make some sawdust.
I am still using Sketchup 2017 for the Mac, which is no longer supported but my current Mac OS will still run it and it has all the features I need. I've messed with the on-line version very briefly and while I think I could live with it for some things, my recollection is that its hard to save projects and, overall, the features are more limited (at least when I last messed with it). One does now have to use the on-line version to import designs from the 3D warehouse, but I can copy them into my Sketchup 2017 version. I've used it since it was a Google product - and certainly in the time up to the 2017 version, there were improvements that have been useful. But it has served me well - and I've designed a couple of fairly complex projects with it. I still managed to slide back down the learning curve when I haven't used it in a while, so I have to relearn things, but for the most part that doesn't seem to be a huge problem that a few expletives can't fix. Trimble does have some pretty good on-line tutorials and there are some Sketchup for woodworkers books out there - the ones I have are by Joe Zeh and by David Heim
I haven't yet had to confront what to do if the 2017 version won't work anymore (my current thinking is to not upgrade the OS on one of my older Macs just to avoid having compatibility issues arise) - I really, really, really dislike "subscription-based" software (thank you MIcrosoft... not).
- Rich
Fire up the google machine and do a search. A good set of tutorials is from Matthias WandelI can't get over the initial learning curve with Sketchup. Anyone know of a good, thorough tutorial online? Something more complete than a short "here's how you draw a board" video?
There's also a lot of info right here on Router Forum - SketchUp Guide for WoodworkersI can't get over the initial learning curve with Sketchup. Anyone know of a good, thorough tutorial online? Something more complete than a short "here's how you draw a board" video?
Does SketchUp have the option to save in an earlier version? The reason I ask is that CorelDraw allows me to save all the way back to Version 11 if I'm sending a file to someone with an older version (I'm on X8 or 18).When someone saves a file in the latest format and puts it up for download the 2017 version won't open it.
But you can use the Save As option and save a version that is compatible with SketchUp 2017.When someone saves a file in the latest format and puts it up for download the 2017 version won't open it. I never really got a chance to use it very much. Made a few drawings with it but never really had a need for it. After 40 years of buyin g CAD programs and none of them still useable It became less practical for me. I found once I built it in SU my desire to build it in the real world was gone....ha! I design a lot of smaller stuff in vcarve as it can be used to cut parts out.
Monthly or yearly pricing programs just don't fit my style. Sometimes I will lay something down for a year and then pick it up again.
Yes it does. But when you pull down a newer version off of the web trying to get a version you can open is a pain. If one had a friend that had a newer version that could open it and save it as a 2017 version that would work. It can be done but it's klunky.Does SketchUp have the option to save in an earlier version? The reason I ask is that CorelDraw allows me to save all the way back to Version 11 if I'm sending a file to someone with an older version (I'm on X8 or 18).
My problem with becoming more (ahem) mature (haven't quite reached excessive maturity yet) is - besides becoming grumpier - rewiring my brain... I think I'll continue to ride this sketchup horse until one of us gives up... One of the things I like about SU is a trick I think I learned from an early Matthis Wandel tutorial about setting up different scenes to give, for example, an assembly drawing and one that is an exploded view that can give dimensions. Here's an example:A great and FREE program for this kind of work is something called DESIGN SPARK MECHANICAL. It works like SketchUp, but it seems even more powerful, and there are ample You Tube training videos for the software.
Joe
