Sanding is not something you relish doing, but if you want a great final result, you'd better get over it. The awful part isn't the large flat areas because you can use a random orbital sander ROS to do much of the work for you. Just don't overdo it on the finished side of plywood.
The parts I hated sanding the most are the curves on rails and stiles, and especially the curves of picture frame stock. It's even been harder once it's assembled. At least it was, then I discovered two things. One is shaped sanding blocks.
The second set with the curves are simple to use. Wrap the sanding medium around them and press them into the curve. Big curve, use the big sanding block. Corners, use the wedge shaped flat. Got mine on sale at Rockler's, but other sources have them. And there's always Amazon https://www.amazon.com/POWERTEC-71620-21-Profile-Contour-Sanding/dp/B091YK4645/ref=sr_1_38?crid=3TEEVOE1HGMV2&keywords=sanding+blocks+for+wood&qid=1644373001&sprefix=sanding+blocks,aps,782&sr=8-38
But what really changed things was discovery of 3M sanding medium
But what really makes these blocks amazing is this stuff, It has a flexible semi transparent backing so it wraps beautifully around even the smallest of the blocks. It is also incredibly long lasting. Flex it a bit and the sawdust falls off and you're back to producing a great finish, and it also seems to do what paper back does, only in about half the time. I like very glossy finishes on some of my picture frames, and I've found using up to 220 is sufficient. I don't find any real improvement going above 220.
I also use a wood filler I found a number of years ago. It's an Aussie produce called Timber Mate. No matter how hard I try, I still get little tiny gaps in miter joints. This stuff gets pushed in, dries, sands and then stains and finishes like the original wood. Comes in many types of wood. Timbermate American Cherry/Brush Box Hardwood Wood Filler 8oz Jar - Wood Fill - Amazon.com
I'm posting this for all newbies and anyone else who is not fond of sanding.
