I was unaware of this shelf pin idea
1.1K views 19 replies 6 participants last post by  RainMan 2.0
So I’m in Edos Japan , and as I’m standing in line I see something I’ve never seen done before , they countersink the shelf pins in their shelf so that they do not move .
So I thought as an experiment I’ll try that on a spare cabinet that I just installed in the tool shed .
I nailed it on 3 shelf pins ,but made a mistake on the 4th , but I just widened it a bit and all is well .
‘I didn’t really spend a lot of time measuring,and just went around the sides of the pins with a carpenters pencil . No room to get a square in on both sides of the pins ,but maybe the front side of the pins would have worked fine .
Anyways I put piece of wood on my fence and clamped it down to act as a stop for when I pushed the fence into the router bit .And yes I’m aware they make shelf pins that has a small plate that you can screw to the bottom , but I wanted to see how this works.
I like it better imo , as it kind of hides the pins too boot.
I suspect every wood worker in the world is aware of this counter sinking pin method other than me lol
It wasn’t so much as hiding as it was holding . When the shelf just sits on the pins it’s not very solid. You pull it ahead 2 inches and it falls ,but when the pins are recessed the shelf seems very solid imo .
Definitely going to do this with shelf’s in my gym now ,but I’ll take my time to hopefully get them as accurate as possible
One way to make sure the shelves do not fall off in an earthquake.
The Japanese have a very special way with wood joinery.
Reactions: RainMan 2.0
Never thought of that . I’m glad you mentioned it because I’m going to make some shelves for my gym‘s cabinets soon the same way .
This is actually going to be helpful , as if I miss by a little bit I can compensate by making holes wider to help with expansion and contraction while I’m at it . Thanks for posting
I had to install some knock-down fittings on the edges of melamine clad chipboard shelves. The easiest way I found was to clamp two boards together, and drill a hole with a wood bit centered on the line where the two boards touched. Gave a half-cylinder hole on either side. The fittings were designed to fit that half-cylinder.
‘Quicker than trying to line up on a router table..
I knew there had to be a better way to line things up ,thx
I made this shelf system 40ish years back and it has followed me through 3 different houses and 3 different configurations. Rather than shelf pins I used pan head screws into keyhole slot cut in the shelf sides. For the shelves that aren't solid wood I widened up the front keyhole slot to account for the vertical side panels expanding/contracting seasonally. Mostly white ash with a mixture of solid ash shelves, laminated chip board with ash trim front edge, and frames for glass inserts.
4D
#20 ·
That’s a very interesting way of doing it . Never heard of doing it that way till now . Can’t see why it wouldn’t work great
