Wow Terry , you are the king of joints . It’s one thing I really have a liking for , and hope to conquer someday . Blind dovetails are my favourite, and I have an Incra table and the fence . Just need Incras other neccesary accessories.
On your first pic , the second drawer from the top and the bottom one are my favourites![]()
So this was all done with Incras system ?
Certainly is Terry. The left to right adjustment seems especially neat for repeatable movements. Routing is pretty new to me other than splining plank edges for laminate floor repairs and splining a plank edge to add a custom reducer edge. I'm learning.It allows for repeatable, “programmable” type cuts. Having a fence that moves in exacting 1/32 increments allows projects you can’t do with a standard fence that you have to bump to fine tune.
More examples:
Business card holders
Whistles that I made to give to the youngest generation at family reunion in an attempt to drive their parents nuts
A trivet that had I think, 56 fence changes that needed to be repeatable. I know it would be easy to make something like this using cnc, but I dare you to try it on another router table.
The advantages of the Incra fence are for joinery and small craft type projects. If you think a router fence is just useful for edge profiling or routing rabbits, dados and grooves then your right, you can do everything you want using your fence to do, but if you want to open yourself up to entirely new ways to use a router table, then an Incra fence will allow you to do things you never consider possible.
It isn’t just the front-to-back movements that offer 1/32 adjustments. The fence offers 1/32 left-to-right adjustment of stops for precise stopped dados and grooves. The superfence add-on also allows for routing tall items safely and precisely.
Terry we are a lot nicer and we would never say anything about someone being to wordy. Your joinery is awesome. Which Incra product are you using?![]()
Plus lots more
Thats kind of the point, the ability to create the kind of joinery Terry demonstrates. No doubt this kind of work is achievable outside of an Incra system, but the time and setup involved would far exceed the speed and accuracy you can have with the Incra. Once you get the hang of the system, the same principles can be applied to other aspects of tabletop router work.....Those cabinet ends are beautiful. I still don't see what that fence does.
But you can, and especially so when you include the information you just did. :wink: I think most guys hate changing a saw setting, then trying to return to the same setting later. Good info and thanks for being "wordy" like me. >I have the Incra LS Positioner 25 with their super system fence. It requires a massively large router table. Truth be told, the only advantage of the LS25 over the LS17 is those rare circumstances where you really need to route a dado another 8 inches further from the end of your board. If I have lots of dados to run I usually use a dado stack on my table saw anyway.
After using the LS Positioner on my router table I decided to go for the same precision on my table saw so I bought one for that, even though my Jet Exacta came with a really nice Bessemer style fence with a second locking knob and micro adjust dial. It’s nice knowing that I can set the fence, make some cuts, change the fence and make more cuts, then change it back knowing the cuts are exactly the same width as the first time. I previously would cut all similar sized parts at the same time knowing that consistency is more important than an exact measurement. Now I don’t have to worry about it, I get consistent results with the right measurement even if I have to go back and cut more piece later. Another advantage of the LS Positioner on a table saw is when cutting really thin pieces, but we aren’t talking table saws here.
There is a third Incra product I really like for precise layouts and that’s the Incra T-rules. Very precise layout lines down to the 64th of an inch or 100th of an inch with the pro T-rules
