1 - 7 of 7 Posts
I have an older incra ls First time trying box joints they are to snug. I was using a Irwin carbide 1/2 inch bit. I checked the bit and it varies from .510 near the Shank to .485 at the tip. I am trying to cut 1/2 inch box joints. My setup may be sloppy I will set it back up again tomorrow. Tired of messing with it today. Any ideas greatly appreciated.
The tapered bit will definitely cause you problems. That may not be the only problem but it is one you need to correct.
I don't like the quality of Irwin tools. Whiteside bits is what I use now. I have been through the problems of using cheap bits.
https://www.hartvilletool.com/category/straight-router-bits
Reactions: furboo
Discussion Starter · #4 ·
Thanks I think the bit is the problem it is a cheap one that came with a set I bought at Lowes. I just bought a whiteside template set and love the way it cuts. Guess I will have to buy a whiteside for box joints.
Buy cheap---get cheap results. Trying to get by with cheap tools is like stopplng your watch to save time. Don't work.
Reactions: Nickp
Exactly, it's not just the taper, and you'll have good luck with Whiteside. I have the Incra, and if the bit cuts less than 0.500", you'll have an interference fit. It's the way the Incra works. I had this issue with my Freud bit (with no noticeable taper), but I can't recall exactly how narrow...something like 0.492". With Whiteside bits, I don't have this issue.
Discussion Starter · #7 ·
Thanks guys
Thanks for all the good input. The best bit I could buy locally was a Freud 1/2 inch shank 1/2 inch straight cut. It miked out at .502, parallel and straight. Cuts great joints fits like a glove. Just cut some 1/2 inch pine to test the fit good friction fit. :smile:
1 - 7 of 7 Posts
