1 - 6 of 6 Posts
· Premium Member
I'd be interested in hearing some of the pro's and con's regarding the Incra Tablesaw systems.
I've no doubts about the accuracy of the units...but..
how about ease of use...
how much extra room on the positioner side is necessary...
does the positioner get accidently bumped around a good bit?
if so, does it stay put..
How functional is the fence?
Is the fence easily adapted for specific jigs etc...
Durability?...
thanks in advance
bill
· Official Greeter
test, test., test
I am surprised that there has been no response in all that time, Bill.
There have been many posts about the Incra systems since 2009.......
· Premium Member
Discussion Starter · #4 ·
Hey James...
I was doing a little housekeeping, figuring out how to get a few threads into my gallery and ended up posting to see if something had worked...none the less...
Yes, I've got to agree with you. I was/am rather surprised myself, Fortunately there has been plenty said in other threads. Enough at least to confirm my initial thoughts that this is a system well worth the investment.
My only real concern is having to move things around in my shop to allow for a "straight on" view of the cursor when making adjustments. Since the far right side of my table sits in front of a structural column.
· Registered
Hi. There
I have had the Incra router table fence for some time and have been more pleased each time I use it. I got the 25" LS about five years ago and a couple of years ago I sent for the base mount kit to put it on my table saw. It has been a blessing to use. To be able to make the same cut after changing the fence setting and going back with complete accuracy. Moving the bridge up to the router table on the left side and than back to the table saw fence stops and it still being on the money. The fence has tracks in the top and the front for attaching add on's. Where my saw sits there is a little room to the right so the fence can be open to it's full width and have room for the positioner.
Yes it takes up more room the a regular fence but the cuts that you can make with it is worth any inconvenience that you may have. As far as being tough and solid it is. Even when cutting big and heavy pcs.
So it may not be for every one but I think that after using one for a while most people would love it. I would probably not want to go back to my old fence and I did have a good fence.
Hope this helps, Bob
· Registered
I have the origional on My router! I can't get down stairs easily, so I am unable to use it on a regular basis! I think that it is great. never mind all the other ones. If I was in good health, I would be able to do more. I need to find the plans book yet. I don't think that I need it untill I look at something realy nice! I know this is an old post, I must of missed it, Had to post on it:)
1 - 6 of 6 Posts
