I'm wondering if anyone has used the Infinity Lock Miter Master Jig. If you have, what is your opinion of it?
I have one, but I'm having trouble using it because the insert has a 1.5" hole so there is no room for the jig to fit on the bit. I can use the jig on the bit if I use an insert with a larger opening, but then the opening is too big and is unsafe. Once I have everything set up, I can't change the insert without ruining the setup.
I saw a video on WWGOA demonstrating how to set up the bit and the fence & that looked pretty straightforward. Maybe I don't need a jig.
If it matters, I'm using 1/2" stock.
