Obiously from my previous posts, I am on the same page as Terry. The Incra Mast R lift along with the the Incra LS system is a great combination.
One thing I learned to do with the lift and the micro adjust feature is that of setting up and cutting miter lock joints.
I was never able to cut cross grain cut in a single pass so I did the following. The first step is to get the height of the bit correct. I have the gauges that some people use but because of vision problem they are hard for me to use and even when I used them the single pass on cross grain just didn't work for me. The material would chatter and buck so that a smooth cut was impssible.
In order to get the height of the bit correct I simple make a ball park practice cut and then using my dial calipers I can measure how far off center the cut is. I first mesure the thickness of the stock and divide by two to find where the center should be. Once I know that I use the calipers to determine where the center of the practice cut is. The center is where the male and female cuts meet. This measurement will tell how much the bit needs to raised or lowered in order to be correct and this adjustment is in thousandths. The accuracy of lift makes adjusting the final height of bit very simple and dead on.
Once that the bit is set the next step is to set the fence so that shallow cut are made. I make several of these shallow cut moving the fence just a little rearward after each cut until the final cut leaves a nice sharp edge at the top of the cut without reducing the width of the stock.
Next I zero the insert in the carriage that has the marks on it with the cursor so that I can, once again go to making my shallow cuts on the actual material being used in the project. I conting making the cuts and moving the fence rearward unto the cursor on the carriage is back to where the cursor on the carriage is on the previous zero mark.
This works for both the cuts with the material flat on the table as well as the ones with the stock flat against the fence for the opposing cut. The results have turned out to be perfect with no chattering during the cuts even with cross cutting in hard wood which was impossible for me earlier. The lift and micro adust used together makes this a simple endevor.
I will be the first to admit that the process could be accomplished without the llft and micro adjust but they do make the job so easy and fool proof, at least it works well for me and I like it. It took all of the frustration of using the miter lock bit for me.
Jerry
Jerry
