Ok. as mentioned in an earlier post I bought a 6mm piece of aluminum plate to make an insert plate with. All went to plan and it is now installed in the table top.
Before drilling the centre hole I thought it a good idea to measure my largest bit that I currently have and I need to drill a 35mm hole to accommodate it.
I know that ready made insert plates come with rings so you can select one to suit the bit size etc.
On my aluminum plate I can't do this (At least I wouldn't know how)
Would it be ok to insert say a 1/4" or 1/2" bit into the 35mm hole and would it be safe to use it this way?
