intro
1648 Views 8 Replies 8 Participants Last post by  KoLdArKnEsS
hi, i found this site from watching the show. needed some info on spiral bits and thought i could get it here. i just retired from G.M. and hope to have more time for wood working now. i do a variety of woodworking. built 3 sets of kitchen cabnets,1 hickory,2 cherry. built 1 strip canoe and am working on my second.also a variety of shelves and cario cabnets. splitcanoe
1 - 9 of 9 Posts
Welcome to the forums.
Welcome to the Router Forums!
Welcome splitcanoe. What kind of questions do you have on spiral bits? I'm sure you will get an answer to your questions. Many knowledgeable people here. G.M. huh? Good for you.
Hey, welcome to the RouterForums.com community! :)
Hi splitcanoe
This is one type of bit you want in your router bit tool box, they can do many router jobs ...
Here are some links and some info about what type you should have.
Spiral Upcut and Downcut Bits
MLCS_spiral_upcut_downcut_router_bits
Spiral Upcut Bit
2 flute flat bottom cutters. Top quality micrograin solid carbide.
Will cut faster, smoother and stays sharper longer. Produces a very clean, fast and accurate cut with minimal chatter. Upcut spiral helps remove material. Ideal for making mortise and tenon joints.
Downcut spirals help hold the material in place while using handheld routers. Will plunge cut and plane edges.
Eliminates chipping at the top of the cut. Ideal for soft & hard woods, plywoods & composites, laminates, plastics and some non-ferrous metals.
Spiral Flush Trim Bit
MLCS_solid_carbide_spiral_flush_trim_bits
Get state of the art results in flush trimming, pattern or template work.
The 2 flute solid carbide spiral bits have two ball bearing guides.
Great for use where chip-out is a concern with plywood, melamine or other laminate surfaces.
Downcut bit is for hand held router applications. Upcut bit is for table mounted router applications.
Overall length for 1/4" bit is 3" and for 1/2" bit is 3-3/4". As seen and recommended in WOOD® Magazine (#158).
Compression Up/Down Spiral Bit
MLCS_compression_up/down_spiral_bit
Compression
Up/Down Spiral Bit
This 2 flute solid carbide bit is needed to get clean, chip-free and splinter-free cuts in composite sheet goods such as Melamine or 2-sided Formica/Laminates and veneered plywood.
The Up-shear/Down-shear design of the bit cuts toward the center of the sheet from both sides at once, saving time and eliminating waste.
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_solid.html
http://www.mlcswoodworking.com/shop...s/bt_solid_sets.html#super_starter_set_anchor
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_solid_sets.html
Bj :)
Welcome to the forum, can't wait to see some of your work!
W e l c o m e . . A b o a r d !!
You will like it here!
Sounds like you could share a few projects with US too!! :) :)
Hi SC, welcome, very interested to see some pics of the strip canoe work
1 - 9 of 9 Posts
