1 - 7 of 7 Posts
Hello all: I'm a new member of the forum. I have a question relating to workshop ventilation.
I'm walling off part of my garage for a dedicted shop. The garage is a "tuck-under" and is directly below a family room. I know how to insulate for noise, have a window in the shop area and will supplement with a exhaust fan.
Here is my concern/question: My wife is very sensitive to volitile fumes (finishing/paint/stain). Does anyone have some good suggestions about how I can "seal off" the shop from the rest of the house as I wall it in?
Thanks in advance,
Greg
Hi Greg
Plastic works well but it's best to do it outside, don't want to tick off the BOSS :)
Thanks in advance,
Greg
Greetings Greg and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
I would recommend out of doors if possible, I keep my shop at a negative air pressure compared to the house when I can which is most of the time.
You might take a look at the ventilation systems and construction methods that are used for spray-booth operations.
I also saw a DIY sort of venting system in a magazine a while back. It used a large, high-volume box-style fan driven by a separate, protected motor on a pulley and v-belt (concentrated combustible fumes and sparking motor brushes aren't a good combination). He had it arranged above a window that he could open, then lowered the fan into position for operation.
Remember, too, that you'll need an air intake source of equal or greater volume than the exhaust.
Discussion Starter · #6 ·
Thanks all. Outside is my first choice, but not a year round option in Minnesota. (although is is a balmy 36 today!)
Negative air pressure, and paint booth ventilation is where I'll do some research now.
thanks again.
Greg
Hello Greg and welcome to the RouterForums.
1 - 7 of 7 Posts
