Hi Harry
Ping-Pong
I got your point but that's why I made one to fit the 1 1/2" BRASS guide, I have many routers and out of them the biggest collet (chuck ) nut is 29mm O.D. and it will not hit the guide, so to say it works just fine..
I had to make my own because in the USA they don't make a 40mm guide in steel or brass...
I will say many of the routers that use the big steel guides use two screws to hold them in place.
unlike the brass ones that use the brass threads to do the same job..brass on brass.. that works like a locking device..
just like a brass fasteners do...deforming the threads just a little bit..
Ping-Pong
I think you may have missed my point about large size template guides which allow not only the cutter to pass through but also the CHUCK, thereby allowing a much deeper cut and no chance of sparks flying when the chuck touches the inside of a small guide. (please don't tell me that steel on brass doesn't make sparks, I know.) Lots of routologists use steel guides without any associated problems arising during decades of use.
