That will leave a 'sloppy' insert You need to rout an intermediate template in MDF then rout the template requirednew here, hello everyone
i have oval and heart shaped peices of marble from an etching company, need to make a jig for the marble to insert into the oak frame, been a woodworker for 25 years and this ones tricky, the easyest way i can come up with is the 1/4 bit with the bushing following the template?
am i on the right track?
thanks
If you rout a template with a 16mm template guide and a 4mm cutter then you can rout the shape you require into the oak frame with a 30mm guide and 10mm cutter. Don't ask me to do the calculations in imperial as it is some 40+ years since we went metric.
Tom
