1 - 4 of 4 Posts
Welcome to the forum.
Thank you for joining us, John.
You will find many on the forum, from hobbyists
to professional with similar interest in the router and its uses.
Take the time to learn how the forum works and ask any questions you want.
Try to post your question in the most appropriate section as not all members
read the Introductions section.
The members are only too happy to help.
Hi John - welcome to the forum! :)
I have the Ryobi BT3K (since the early 90s) and just replaced w/ a Steel City TS earlier this year; the Ryobi machine is pretty much 'entry level' for TSs (as you probably already know); I've kept the TS loaded w/ my 6" dado blade for small cuts.
If not already done, I would suggest visiting BT3 Central, which is dedicated to these Ryobi TSaws and likely will have much more information for you in resolving this issue - good luck! Dave
Discussion Starter #4
Thanks and I solved my problem. I let it sit for a week and put it back together and the blade went up and down fine incuding after I tightened the screws. No Idea what made the difference.
1 - 4 of 4 Posts
