My toonie is,it is a PITA to swap a router out of the table to use as a hand held, get 2 routers that fit your needs separately.
Yes that’s the plan . Get the 1617 for a lift , and the 23 for plunging . I have the Festool 1400 and to tell you truth I don’t like the ergonomics of the handles .My toonie is,it is a PITA to swap a router out of the table to use as a hand held, get 2 routers that fit your needs separately.
Not understanding the question? The Festool 1400 is a routerIs that kind of like the handplane collectors? I have known some that have walls and drawers full of planers, and never do a lick of woodworking, or have sharpened a single plane.
yup!!!!my toonie is,it is a pita to swap a router out of the table to use as a hand held, get 2 routers that fit your needs separately.
My point was there are people too that collect routers and never use them all. I am one of those I have several routes I have never used, still in the box, I guess you could call them spares. (no HF)Not understanding the question? The Festool 1400 is a router
if you had them from you'd need a truckload of them as ''spares''....My point was there are people too that collect routers and never use them all. I am one of those I have several routes I have never used, still in the box, I guess you could call them spares. (no HF)
I have a few spares around still in the box. Instead of changing worn-out brushes in a router you can just chunk the old router in the trash and get a new one out a box. Keeps your hands clean.>My point was there are people too that collect routers and never use them all. I am one of those I have several routes I have never used, still in the box, I guess you could call them spares. (no HF)
I had to go back and reread that, "How'd Herb get started on Greek food???"My toonie is,it is a PITA to swap a router out of the table to use as a hand held, get 2 routers that fit your needs separately.
Bosch MRF23EVS vs Bosch 1617EVS ? Which is the Better Router?Was watching a video on the MRP23EVSK, and I see they made some improvements.
One thing I like is it actually has led lights built in , plus the power switch is on the handle making it more ergonomical .
But I mostly hear about the 1617EVSPK on the forum .
My idea was to buy the 1617 with its fixed base as it’s cheaper , and use it in a router table with a lift possibly, and to buy the MRP23 for plunge routing .
But they look mighty fine displayed on the walls. Gives a look of an old timer..........Is that kind of like the handplane collectors? I have known some that have walls and drawers full of planers, and never do a lick of woodworking, or have sharpened a single plane.
Now that's funny! A very good sense of humour!I had to go back and reread that, "How'd Herb get started on Greek food???"
Thank you for your input Charlie . I’ll only be using the 23 as a plunge router and the 1617 mounted in a lift , so shouldn’t have any issues .I had good luck with the 23(but then I had bad luck with a Porter Cable so maybe I should shut up) Oh well charging ahead, the switch in the handle design helps with control especially when shutting down at the end of routing a freehand design.
I have messed up some projects using my palm router trying reach over and shut the unit off.
The only issue I ever had with the 23 was trying to use it in a table-the lift is a bad design and dirt in the switch causing it to fail. The dirt in the switch problem never showed up when using the unit out of the table.
It has a heavier feel to it compared to my 1617 when free handing which helps me with control.
Rick, in my opinion, a footswitch is an accident waiting to happen. Not just because you could end up with cut fingers but we all, or at least I have a bad habit of piling things on empty flat surfaces. That might throw things if the switch gets stepped on accidentally. Again that is just my opinion.One thing I was wondering, is why people couldn’t incorporate a foot switch to shut their router off and on if your free handing something.
Seems like it would help in some situations where the router doesn’t have an easily accessible switch .
1... agreedRick,
1... in my opinion, a footswitch is an accident waiting to happen.
2... I have a bad habit of piling things on empty flat surfaces.
