Isolating the bearing is a practice used when using a bearing guided bit with the fence. All it means is setting up the fence so that it an the bearing are in exactly the same plane. This gives you the full cut of the bit, while using the much greater supporting area of the fence instead of the bearing on the bit as a guide.
Staying on the cutting side of the bit is a safety issue. If you are making an unbalanced cut, like a rabbet or another edge treatment, you want to make sure that the only portion of the bit that is engaging the work is the "cutting side". If you can look at your bit, and see the face of the carbide insert in the flute, that is the cutting side. If you see the back of the flute, that is not. Sounds simple enough, but if you try to take too big of a cut, you can get into an unsafe situation. Staying on the cutting side puts the force of the router bit back against your feeding pressure and up against the fence. If you get off the cutting side, the bit can climb cut and steer your stock where it wants to go. This can pull your stock or your hand feeding it through the router.
Hope this is an adequate definition, I'm sure others will be able to amplify.
