1 - 5 of 5 Posts
· Registered
Anyone else here bought an MLCS router speed control and have it not work on the speed side?
Also what is up with no mounting brackets. A belt buckle mount is NOT a good idea for mounting an electrical switch!!!!!
Anyone have plans for a speed control, so I could mount it behind a wall and put the controls in a conventional electrical box so they could be mounted into a wall? Or a source for something like that?
· Registered
Discussion Starter · #2 ·
Well NOW I have read that some router speed controls will not work with routers that have soft start and or speed controls on the router itself. Our Bosch 1617 routers have both soft start and built in speed controls!!! All fine and good IF you are using the router when it is not mounted in a table with a dust control box but not worth a flip if you have to reach up under the table and find the speed control knob!!!!
So anyone else have this issue and did you find a work around?? I would REALLY like to have the speed control up where it is easy to reach!!!
Maybe an Adrino controller??? Like for a CNC??
· Registered
Best one for CNC is the SuperPID
Unfortunately you will need to build it by adding a heatsink and a box and also bypass the internal soft start and built in speed control.
Routers that have an internal speed control (or soft-start feature) can usually by bypassed relatively easy by joining the all 3 pins/legs of the router's internal TRIAC device. This is reversible.
· Registered
Discussion Starter · #4 ·
My partner has the exact same router and a different speed control. His works fine. I tried his speed control on my router and it works fine. So I have one on order. Not sure what is up with the MLCS 20amp version.
Thanks for the link. I am going to look into that further. The Shark is a really cool system and I would like to match it with an equally cool speed control.....
I just made 8 corners of a box joint build in about 10 minutes with the system!!! Fit was machine perfect and i am still learning!!
· Registered
Perhaps this will help. I use the MLCS 20amp version speed control with a Hitachi ½" Electric Plunge Router Type TR-12. With several of the controllers, after a number of uses they stopped working; the router wouldn't even start with the speed control connected. An electronics store analyzed the electronics and suggested replacing the TRIAC with a 40 amp version (TRIAC NTE 56031 from Arrow Electronics). After doing that they have worked fine now for over a year.
PS: TRIAC (Triode for AC) is a semiconductor device that is commonly used in power regulation and switching applications. It is used in switching, brilliance control in lights, speed control in fans and motors, etc.
1 - 5 of 5 Posts
