Router - PC 892
Speed - 10000 & ~13000 RPM
Bit - Bosch 84703MC 14deg dovetail (1/4 collet)
Table - Bosch RA1180
Stock - The best 3/4" pine Lowe's has to offer... or, the only wood in the store.
Depth of cut - 1/4"
This is my first router project since highschool (25 years ago). I have started making test cuts in preparation for this project.
When making a dado cut for shelving I am seeing 'fraying' of the wood along the edge of the cut. This is only happening when I cut the slots. Cuts for the dovetails on the shelves themselves are clean and smooth. The fraying is consistant along the entire length of the cut. After a couple of cuts at 10k rpm I increased the speed to around 13k but the results were the same.
The wood that is not completely removed is easy enough to clear off with my fingers. But I would prefer to be making nice clean cuts if possible.
I have included some photos of the router table setup, the frayed dado, and a joined test.
My questions are:
A - Am I using the router incorrectly? I don't think I am. I have seen this done numerous times so I believe it is within the capacity of a router to make this cut. The case for the dovetail bit even shows a dado cut. I recall making these cuts back in the olden days, but not with a dovetail bit.
B - Do I need to be cutting deeper for the groove? I just eyeballed it.
C - Am I using the wrong speed for the wood stock? Should I be going even faster with pine?
D - Is this just a characteristic of pine? Would a harder wood provide a smoother cut?
Any advice would be greatly appreciated.
Thanks,
Dave
Depth of cut - 1/4"
My questions are:
Thanks,
Dave
