I am experimenting with Azek pvc trim wood. I am using a 3/8" upcut carbide and cutting at 50ipm and 20000 rpm router. I am also cutting the .750 stock at .125 per pass. I've got pretty good suction, but at the end of the cut the chips literally remain glued to the workpiece. So I know it's heat related, but have no idea how to eliminate it.
I've tried all different router speeds; I've even elevated the board so that there's space under it during the last cut.
I like the material because it creates little dust and cuts cleanly. However, if stuff gets glued on it, it's tough to remove.
Perhaps there's a cutting technique other than going vertically on each pass. Perhaps I can use a multipass approach, where the tool starts farther from the actual line and works its way in. It's expensive wood, and hate to waste it trying to experiment without any clear ideas.
any ideas?
tc
any ideas?
tc
